高清电视类型统计
关键词:智能家居 投影系统 液晶显示器 家庭娱乐系统
时间:2015-07-21 10:51:37      来源:网络
国际即时新闻(原文:英文)
Clearing the Static on HDTV Types
When you're trying to pick out the right HDTV for your needs, the available products break down into three major product groups distinguished from each other by their display technology and cabinet type. By comparing display technology and cabinet type to your needs, you can easily rule out a whole bunch of different TVs, and home in on the likely best ones for you.
Size and shape
HDTVs come in all sorts of different sizes and shapes. Some are flat-panels that you can hang on the wall; others are projection systems like what you'd find in a movie theater. And, of course, there are HDTVs based on tubes that look just the way TVs have for decades (only with a better picture).
Each form of HDTV has some advantages and disadvantages, and this article is just a quick overview to help you on your way.
Flat-panel HDTVs
Flat-panel TVs — the super-thin models that you can literally hang on the wall — are the sexiest HDTVs available. These are the ones you see on MTV Cribs and that you might install in your tricked-out Escalade (yeah right). They're also good HDTVs. There are two main display technologies for flat-panel HDTVs:
Plasma: These are the biggest flat-screens available, using a layer of gas trapped between two glass screens to create their images.
• Pros: thin, sexy, good picture, good color, big
• Cons: not all are HDTV, less-than-perfect black, screen burn-in, costly
• You'll see the term "blacks" mentioned here. It refers to how well an HDTV screen can reproduce dark tones and scenes on-screen — how well it creates black rather than gray colors.
LCD: These flat-panel TVs use liquid crystal displays, just like those used in laptop computers.
• Pros: same as plasma, no burn-in
• Cons: black is poorest, costly, angle of view
Projection HDTVs
These are the TVs that project their picture from a smaller image source (either three small picture tubes, or a digital system known as a microprojector) onto a screen. The screen can be either part of the HDTV itself (rear projection) or a separate screen hung on your wall (front projection).
Front-Projection HDTVs: These are the HDTV equivalents to movie theater projectors, with a big screen on the wall, and a separate projector mounted somewhere across the room.
• Pros: biggest screen, potentially best picture, can be portable
• Con: expensive, complicated, requires setup/focus/maintenance
Rear projection HDTVs: The picture is projected on the back of a screen that is built into the HDTV itself.
• Pros: best bargain, no burn-in with microprojectors, near flat-panel thinness for microprojector
• Cons: burn-in for CRT, expense for microprojector, bulky size for CRT
CRT HDTVs
The final category of HDTVs is based on the good old-fashioned picture tube — also known as the CRT, or cathode-ray tube.
Pros: cheapest, great color, great blacksCons: smallest screen, bulky, lower resolution than digital displaysWhat's important in an HDTV
When looking at HDTVs, the following are the most important buying criteria for your purchase:
What's your budget? Consider the cost of the TV set, plus the money you'll spend on any attached home theater surround-sound system, special remote controls, automated drapes, lighting controls, popcorn poppers, and the like. It makes a big difference if you're building a home HDTV theater or just putting a TV on the bureau in the bedroom.What size do you need? No, bigger is not always better. You can have a TV that's too large for your space or too small for your usage. There is an optimal range based on where you intend to place the TV and where you intend to sit. These first two items — size and budget — will do a lot to narrow your choices before you get to any of the technical or usage criteria, so they are important to nail down first. If you want to fill an 8-foot wall with an image, unless you have a bank account the size of Bill Gates' you're not going to do that with anything but a front projection system.What do you plan to do with it? Are you going to be watching a lot of sports events? Movies? Video games? Believe it or not, certain types of HDTVs are better with certain types of content. Sports fanatics will find a big, bright DLP projection system better for their tastes, everything else being equal, while people who watch CNN all day long will want to avoid plasma screen displays in a big way, due to the burn-in effects of static images.What will you hook up to it? If you already have a decent investment in A/V gear, then that gear might dictate certain types (and numbers!) of interfaces or ports on your HDTV system, like these:
• If you have an entertainment system designed around centralized video switching — using a receiver to switch among video sources and destinations — then you're going to need a receiver that can switch HDTV content. That might mean a new receiver, which can be pricey and cut into your budget.
• Do you need a tuner or just an HDTV-ready display — meaning you'll get your HDTV tuner from your cable or satellite company?
What neat features do you want? It's easy to be swayed by neat features, but in lots of implementations, you can't access them for various reasons. For instance, if you set up your system so all your signals come in over one cable connection, you might not be able to use your TV's dual-channel features — you could rely on your cable or satellite box for that.
One thing is for sure: Prices become lower as time passes. In deciding how much to spend overall, remember this: Your home entertainment system is probably one of the most-used parts of your home. It helps define your family, social life, business relationships, and so on. These are the places where you personally make a substantial investment because it gets the most use.
中文自动翻译,供参考
高清电视类型统计
当你想挑选出合适的HDTV为您的需求,现有的产品分解成三大产品群相互区别在于他们的显示技术和柜式。通过显示技术和柜式比较您的需求,您可以轻松地排除了一大堆不同的电视和家庭在对可能的最好的给你。
尺寸和形状
高清电视来在各种不同尺寸和形状。有些是平板显示器,你可以挂在墙上;另一些投影系统像你会发现在一个电影院。当然,也有基于高清电视管子,看起来只是电视的方式几十年来(仅一个更好的图片).
HDTV的每种形式都有一定的优势和缺点,这篇文章仅仅是一个快速的介绍,帮助你对你的方式
平板高清电视
平板电视 - 超轻薄机型,你可以从字面上挂在墙上 - 可在高清电视最性感。这些都是你在MTV婴儿床中看到的,并且你可能在你的骗出安装凯雷德(是正确的)。他们也很好的高清电视。有两种主要的显示技术的平板高清电视:
等离子:这是最大的平板电视用,使用气体层两个玻璃屏幕之间被困打造自己的形象的?优点:轻薄,性感,不错的画面,显色性好,大
?缺点:并非所有的都是高清电视,低于完美的黑色,屏幕老化,成本
?您会看到这里所说的“黑人”一词。它指的是高清晰度电视的屏幕可以如何重现屏幕上的暗色调和场景 - 以及它如何产生黑色而不是灰色的颜色
LCD:这些平板电视用液晶显示器,就像那些在笔记本电脑中使用<。 P类=“文章-UL2”>?优点:相同的等离子,无老化
?缺点:黑色是最贫穷的,昂贵的,视场角
投影高清电视
这些的电视伸出的从较小的图像源(三个小显像管,或称为显微投影数字系统)投影到屏幕上的图像。该屏幕可以是部分的HDTV本身(背投)或单独的屏幕挂在墙上(前投影).
前投影高清电视:这是HDTV等同影院投影机,与墙壁上的大屏幕,和一个单独的投影机安装的地方穿过房间?优点:超大屏幕,可能最好的图片,可以是便携式
?缺点:价格昂贵,复杂,需要设置
对焦
维修
背投高清电视:图像投射在被内置于高清电视本身屏幕的背面?优点:最便宜的,不老化测试与微投影,近平板消瘦的显微投影
?缺点:老化的CRT,费用显微投影,支持CRT
CRT高清电视
高清电视的最后一类庞大的大小是根据在老式的显像管 - 又称CRT或阴极射线管
优点:最便宜的,伟大的颜色,极大blacksCons:最小的屏幕,体积大,分辨率比数字displaysWhat的重要的HDTV
下当看着。高清电视,以下是最重要的购买标准供您选购:
什么是你的预算是多少?考虑电视机的成本,再加上你的钱会花任何连接的家庭影院环绕音响系统,特殊的遥控器,自动窗帘,灯光控制,爆米花樽等。它使一个很大的区别,如果你正在构建一个家庭影院高清电视,或只是把电视机上局在bedroom.What大小,你需要什么?不,更大并不总是更好。你可以有一个电视这是太大的空间或太小为您的使用。还有根据你打算放置电视和你打算坐是一个最佳范围。前两个项目 - 规模和预算 - 会做很多之前你到任何的技术或使用标准,以缩小选择范围,所以他们是很重要的敲定第一。如果你想填补一个8英尺高的墙与图像,除非你有一个银行帐户比尔·盖茨的“你不打算做任何事情,但前投影system.What你打算用它做大小?你将要观看大量的体育赛事?电影?视频游戏?不管你信不信,某些类型的高清电视与某些类型的内容更好。体育爱好者会发现一个大的,明亮的DLP投影系统更好地为他们的口味,其他一切都是平等的,而人谁看CNN整天都希望避免的一大途??径等离子屏幕显示,由于老化的静态效果images.What你会挂钩呢?如果你已经在A
V齿轮像样的投资,那么这可能齿轮规定某些类型(和数字!)你的高清晰度电视系统上的接口或端口,像这样的:?如果有娱乐系统设计围绕集中式视频切换 - 使用接收器的视频来源和目的地之间切换 - 那么你会需要一个接收器,可以切换HDTV内容。这可能意味着一个新的接收器,它可以是昂贵的,切成你的预算.
?你需要一个调谐器或只是一个HDTV就绪显示 - 这意味着你会得到你的HDTV调谐器从有线电视或卫星公司?
什么整洁的功能,你想要什么?这很容易通过简洁的功能所左右,但在很多实现的,你不能访问他们因各种原因。例如,如果您设置系统,使所有的信号都在一根电缆连接,你可能无法使用电视的双通道功能 - 你可以依靠你的有线或卫星电视盒为有一件事是肯定的:价格变得更低随着时间的推移。在决定要花多少钱总,记住这一点:你的家庭娱乐系统可能是你家中最常用的部分之一。它可以帮助你确定家庭,社会生活,商业关系,等等。这些是你亲自作出重大投资,因为它得到最普遍使用的地方。
